查看: 4885|回复: 15
西班牙海军F-105宙斯盾护卫舰
  • 发表于 2009-11-28 09:10:34 | 显示全部楼层 |阅读模式
    F-105 Spanish Aegis Frigate
    by Bill Liebold
    1/96 (Scratchbuilt)
    Here are photos of my 1/96 scale F-105 Spanish Aegis Frigate. As you can see it took more than a hit during shipping. When I first built it I had to get it out the door before the photo etch came back from the vendor. The photos of the finished model are after the repairs and I had the photo etch on hand to install it during that time. I even had a little extra time to add other details that I didn't have time for the first time around such as the boat davits. The model is mostly basswood like the other models I've built in this scale. I don't know what they did to cause that kind of damage. The all thread was sheared off at the bottom of the hull and the base was cracked over half of its length. I've had models of this scale shipped back upside down and on their sides (figure that out, the cases have wheels on the bottom) with no damage at all. When you send models to trade shows all over the world damage is a fact of life. So far I've only had two models that were damaged to the point of being a total loss.
    F-105西班牙宙斯盾护卫舰
    制作者:Bill Liebold
    比例:1/96(从零开始)
    这里是我的1/96比例的F-105西班牙宙斯盾护卫舰的照片。正如你可以看到它在运输过程中受到多处损伤。当我第一次制作它,在蚀刻件从供应商处返回之前,我不得不带它出门。成品模型的照片是在维修后,并且在此同时我安装了手头上有的蚀刻件。我甚至有一点额外的时间来添加其他细节,如船吊艇架,我第一次做的时候没有时间弄它。该模型主要是椴木,就像我以这个比例制作的其它模型。我不知道他们做了什么造成的这样的损害。在船体底部的所有螺丝被切断和基座的裂缝超过了它的长度的一半。我已经运回了这个模型,侧面(图解,整个后部)没有任何损伤。当您发送模型去交易显示在世界各地损害是一种生活现实。到目前为止,我只有两个被损坏,是全部损失。
    少尉 该用户已被删除
    发表于 2009-11-28 10:58:59 | 显示全部楼层
  • 发表于 2009-11-28 11:36:00 | 显示全部楼层
    [vse4bb]让人羡慕的工作室
    5imx 该用户已被删除
    发表于 2009-11-28 12:11:18 | 显示全部楼层
  •  楼主| 发表于 2009-11-28 14:06:25 | 显示全部楼层
    [vse4bb]让人羡慕的工作室
    奥比王 发表于 2009-11-28 11:36
    偶怎么觉得那是一个仓库的一角~~
    发表于 2009-11-29 00:16:20 | 显示全部楼层
    眼珠子都 快 掉出来了
  • 发表于 2009-11-29 07:38:07 | 显示全部楼层
    新型舰艇模型很吸引人。[vse4bb][fbdsbsb]
    deepyearn 该用户已被删除
    发表于 2011-5-4 10:32:55 | 显示全部楼层
  • 发表于 2011-5-12 20:55:17 | 显示全部楼层
    漂亮,严重羡慕中!
    发表于 2011-5-13 08:18:27 | 显示全部楼层
    相当的邪恶!!!!!!!!!!!
    GMT+8, 2024-11-28 14:40 , Processed in 0.114179 second(s), 29 queries .
