查看: 5289|回复: 14
一个皇家海军“胜利”号截面的场景(3)- 9.28更新
  • 发表于 2009-10-12 21:06:35 | 显示全部楼层 |阅读模式
    这是制作者在9月28日的更新~~
    The Middle Gun Deck
    I am now going to the middle gun deck.  Below are some samples of the figures I am using.  Many of my figures started out as Micro Aggression wrestlers that I purchased (they are on the right).  My modied figure is on the left.  In many instances, I discarded their bottom torso and replaced them with torsos I casted from other 1/32 scale figures.  I modified their upper bodies trying to make them less muscular.  In some cases I added "body fat."  In the 6th and 7th photos down below are the scratch built figures I made from a W. Britians figure set I purchased (they are on the right).  For these I made a two piece mold and casted in resin my figures.  The marine I casted had a fancy "feather" on his hat like the original, but I cut it off since the gun deck was too low.  In addition to the group seen in the last photo, I later added another sailor who was injured.  He can be seen in some of the other middle gun deck photos.
    我现在到了中炮甲板。下面是我使用的人偶的一些样品。我的许多人偶启用我买的小型摔跤手(他们在右侧)。我的改造人偶在左侧。在许多情况下,我丢弃其下部躯干,用我从其它1/32比例的人偶的躯干取而代之。我修改了他们的努力减少他们上半身的肌肉。在某些情况下,我又增加“脂肪”。在第六和第七的照片里都制作了人偶,我用我买的(他们在右侧)W. Britians人偶系列制作的。对于这些我做了两件模具和树脂铸造我的人偶。我铸造的水兵最初帽子上有花哨的“羽毛”,但因为炮甲板太低,我将它切掉了。除了在照片上看到的一组,我后来又增加了受伤的水手。可以看出,在中炮甲板的其他一些照片中可以看到他。
  •  楼主| 发表于 2009-10-12 21:09:36 | 显示全部楼层
    [fbdsbsb] [fbdsbsb] [fbdsbsb]
    Now some photos of the figures in place on the middle gun deck without the roof on.  This is the fun part, placing the figures in place.  They have been secured with a pin place through the foot and ankle and epoxied in place.  The cannons here are 24 pounders.  The cannon barrels were casted in resin from a master I turned and the carriages are made from yellow heart wood.  Figures were modified (mostly in arms and hands) to show some type of activity.
    现在,出现的是没有屋顶,放置了人偶的中炮甲板的一些照片。这是最有趣的部分,配置了人偶。他们已经用针穿过足部和脚踝,然后用环氧胶固定了。这里的大炮24磅的。炮管是从一个我车制的原版用树脂铸造的,炮车是由黄心木的。人偶进行了修改(主要是臂和手),以显示动作的类型。
  •  楼主| 发表于 2009-10-12 21:12:20 | 显示全部楼层
    Here are more photos of the middle gun deck, most with the roof (floor of the upper gun deck) in place.  The gun port lids will not be put in place until the model is nearly finished.  I think they could easily be knocked off if in place now.  On the outside of the hull in yellow is yellow heart wood and the black is ebony.
    这里是中炮甲板的更多照片,这里大部分带屋顶(上炮甲板的地板)。炮窗的盖子到模型快完成时再放上去。如果现在放上,我认为它们很容易被碰掉。船体外侧的黄色是黄心木和黑色是黑檀木。
  • 发表于 2009-10-12 21:46:19 | 显示全部楼层
    [vse4bb][vse4bb][vse4bb]
  • 发表于 2009-10-12 23:36:09 | 显示全部楼层
    [vse4bb][vse4bb][vseevwcw]
    沈水扬帆 该用户已被删除
    发表于 2009-10-13 09:03:11 | 显示全部楼层
    Disney 该用户已被删除
    发表于 2009-10-13 09:14:19 | 显示全部楼层
    5imx 该用户已被删除
    发表于 2009-10-13 09:31:55 | 显示全部楼层
  • 发表于 2009-10-13 09:53:10 | 显示全部楼层
    [vse4bb]原来人物是这么做的,看来要多收集些不同动作的小人了
  • 发表于 2009-10-13 13:24:50 | 显示全部楼层
    好热闹的场面,个个像拳击手。[fbdsbsb]
    GMT+8, 2025-3-3 07:29 , Processed in 0.093129 second(s), 28 queries .
