TA的每日心情 | 慵懒 2020-1-16 08:06 |
HMS Grey Goose
by Edward Pinniger
1/96 (John Piper Models)
The 145-foot Steam Gunboats (SGBs) were the largest of the Royal Navy Coastal Forces small craft, and the only ones to be steam-powered and to have steel rather than wood hulls. Powered by twin steam turbines, they had a maximum speed of 35 knots, not much less than that of the smaller Motor Torpedo Boats (MTBs) although their acceleration was poor. These craft were very heavily armed for their size; HMS Grey Goose as represented by my model (in mid-war fit) has one 3” gun, two 2pdr “pom-pom” guns, two 20mm Oerlikon guns, two twin Vickers .50 machineguns, two torpedo tubes, and depth charge racks! 60 SGBs were originally planned to be built, but due to lack of shipyard space, only 7 were actually completed. They were built in 1941-42, by several different shipyards (Grey Goose was built by J. Samuel White, Cowes)
The John Piper Models 1/96 scale kit of HMS Grey Goose was produced in the early 1980s, along with a Flower-class corvette in the same scale. Sales were apparently poor (probably due to their very high price, along with the much cheaper Matchbox 1/72 corvette being released around the same time) and they were not in production for long. They can still occasionally be found on the second-hand market, usually at quite reasonable prices given their quality and original cost.
The John Piper kits have resin hulls, etched brass superstructures, and fittings and detail parts made from cast white metal and photo-etched brass. Their quality, detail and accuracy is very impressive even by current standards! - there really isn't much that needs to be changed or added to even by the most demanding modeller. The only negative points are a few parts (such as the prop shafts) supplied as metal castings which really ought to be made up from brass wire, like the mast; and the photo-etched railings, which in 1/96 scale look much better as individual stanchions rigged with wire. This is what I did (using Dean's Marine 1/96 PE stanchions). Other than this, my model is built "out of the box" and painted as HMS Grey Goose (S309)
“灰鹅”号
制作者:Edward Pinniger
比例:1/96
套材:John Piper Models
145英尺的蒸汽炮艇(SGBs)是皇家海军沿海部队小型船艇中最大的,唯一的蒸汽炮艇,它是钢质船体,而不是木质船体。由两台蒸汽涡轮机,时速最高可达35海里,不低于小型摩托鱼雷艇(MTBs)尽管他们的加速度低。这些小船以其大小则是武装充足;如我的模型“灰鹅”号为代表(中旬战争适合)有一门3"炮,两门2磅的“聚甲醛,聚甲醛”炮,两门20毫米Oerlikon机炮,两挺双联Vickers0.50机关枪,两个鱼雷发射管,和深水炸弹发射架!原计划建造60艘SGBs,但由于造船厂缺乏空间,实际只完成了7艘。他们都是在1941年至1942年,由几个不同的造船厂建造的(“灰鹅”号是由在考斯的J.Samuel White)。
John Piper Models的1/96“灰鹅”号产于20世纪80年代初,与花级轻巡洋舰同一比例。销售显然差(可能是由于其高昂的售价,同期Matchbox推出的1/72的轻巡洋舰更便宜),并且它们不是长期大量的生产。它们仍然可以偶尔在二手市场上找到,由于其质量和原始成本,价格通常是相当合理的。
John Piper套材有树脂的船体,蚀刻铜片的上层建筑,及配件和细小零件由白色金属铸造和蚀刻铜片。他们的质量,精细和准确度以通常的标准是非常令人印象深刻!真的是没有太多需要更改或添加的,即使是最苛刻的模型制作者。唯一的不足之处是少数零件(如螺旋桨轴)提供的是金属铸件,实际上应该由铜丝制作,如桅杆,蚀刻的栏杆,以1/96的比例应该比单独用铜丝制作的更好。这就是我为什么使用Dean's Marine的1/96的蚀刻支柱。除了这个,我的模型是“开箱即用”的和以“灰鹅”号涂装的( S309 ) |
