查看: 3896|回复: 15
关于宪法号剖面的历史舰型考证及疑问【1.9更新】
发表于 2014-1-7 14:30:19 | 显示全部楼层 |阅读模式
    很久以前做过进度30%的宪法号剖面,剖面所用图纸为常见的那套套材图纸,自己重新制图A4画幅1:80比例,这套图纸所参考的舰型为目前停靠在波士顿的当前舰型。
    现在打算利用过年的时间把其做完,想把舰型的版本改为1812年的版本,目前遇到很多疑问。
一.舰型的考证
【参考资料:The 44-Gun Frigate USS Constitution】
1797年下水舰型
可以看到其臼炮甲板并无船舷,只有围栏
1812年大修后舰型
可见臼炮甲板前后端都有船舷包围并开有炮窗中段为防护网
目前舰型版本
可见中段也有船舷包围,炮窗位置调整。
    想以1812年舰型为蓝本,改造宪法号剖面。
二.遇到问题
1.水泵版本
    原套材图纸中水泵为双联压杆型水泵,并且无火炮甲板下水管部分制作(此为图纸绘制缺陷,并且市面所售套材大多延续了这一缺陷)
但是这一水泵类型在The 44-Gun Frigate USS Constitution中并无提及,我在American.Heavy.Frigates.1794-1826 中找到了这一版本,但年份不明,舰型为当前舰型。如图:
而The 44-Gun Frigate USS Constitution中所注水泵为压杆水泵和链式水泵,如图:
    这本书的以上两张图存在着矛盾,第一张图显示链式水泵在1814年装在宪法号上,而第二张图显示在1812年的内构图中就已经使用链式水泵。
    所以如果我制作1812年舰型,应该选用双联压杆水泵/压杆水泵/链式水泵的哪一种?
其他问题继续中。。。。
今天看到的一段文字,解释了关于宪法号水泵的问题:
http://usscm.blogspot.com/2013/0 ... r-constitution.html
为blogspot里的文章,国内应该打不开,转载过来看看:
Patent Pumps for Constitution
Wooden ships leaked. Some leaked more than others. It was a fact of life well known to every sailor. Every few hours at sea, the ship’s carpenter rigged his sounding rod, a sort of overgrown dip-stick, and “sounded the well.” If all was tight, he’d find only a few inches of water accumulated in the hold. But if the ship had experienced stormy weather, or had suffered damaged to its hull, the carpenter might discover several feet of water in the well. Repeated soundings a few minutes apart told him if the water was rising.  If so, the order to rig and man the pumps rang through the ship, and a gang of sailors took hold of the pump handles (called brakes). Up and down they worked, drawing the water up through the pump dale till it reached the deck and ran out the scuppers into the sea. If they pumped fast enough, the pump would soon “suck,” indicating that all the water had been discharged. If the water continued to rise, even with the pumps working, then they were all in for a bad time.
Inventors frequently tinkered with pumps and by the late eighteenth century a number of improvements had made them fairly efficient.  Most ships carried a species of “chain pump.” William Falconer’s New Universal Dictionary of the Marine (1815) defined the pump as “a long chain equipped with a sufficient number of valves at proper distances from each other, working upon a sproket wheel [sic], and passing downward through the back-case, then returning upward through the round chamber, by which means the water is pumped out of the ship’s hold. It is managed by two winches, whereon several persons may be employed at once; and thus it discharges a greater quantity of water than any other pump hitherto invented, and is worked with less inconvenience to the seamen.”
Plate 19 of Falconer's New Universal Dictionary of the Marine shows the details and internal workings of a typical chain pump.
When they worked, they worked well, but they were liable to breakage and clogging- often at the worst time.
As Constitution lay on the stocks at Edmund Hartt’s Boston shipyard during the winter of 1795-96, Secretary of War James McHenry began to order the vast number of items needed to outfit the ship. In January 1796 he commanded Naval Constructor George Claghorn to fit the ship with chain pumps and to position them just before and behind the main mast.[1]
The red arrows point to Constitution's pumps in this detail from Charles F. Waldo's 1816 plan of the ship's orlop deck. National Archives plan #14949
Technology never stands still, and to his credit, Secretary McHenry frequently embraced new inventions conceived by enterprising Americans- provided they really worked. Philadelphian Theobald Bourke had recently patented a new suction pump that operated without chains, and he eagerly showed it off to prospective buyers. Newspapers across the country printed the results of a December trial.
PATENT PUMP
Agreeably to an advertisement of the subscriber, a number of gentlemen met at Vine-street wharf on the 12th inst[ant- i.e., the 12th of the present month, in this case December 1796] among whom were John Barry, Esq. commander of the frigate United States, and Mr. Joshua Humphries, naval constructor, to see the performance of Bourke's United States patent COPPER PUMP, which answer’d their most sanguine expectations. It deliver’d that day one hundred and fifty-four gallons of water, in thirty-five seconds of time, by several stop watches, and thirty-eight strokes of the pump break, although some water was lost: it also lifted up and discharged through the valves a quantity of stones and gravel, and a 4 pound shot. To all owners and masters of vessels this pump must be a valuable acquisition, where lives and property are at stake—another advantage attending this pump is its simple construction; any mariner can put it in order. The chain pump is liable to choke, and requires more men to work it; this pump will not choke either with stones, gravel, or grain, and only requires four men to work it with the greatest power. Two men can work it, and discharge half a tun of water per minute. He can make them to accommodate small as well as large vessels. This pump, for which the subscriber has obtained a patent from the United States of America, and an exclusive privilege to make and vend the same, may be of effectual service to all brewers, distillers, or in raising water to a great height in inland navigation, as well as to raise water for overshot mills. The subscriber may be spoke with at his shop in Water-street, opposite the Swedes church, and expects from the public the encouragement that his invention and attention may deserve.
        THEOBALD BOURKE. [2]
A week later, Captain Barry, along with Joshua Humphreys and Captain Thomas Truxton, made an ecstatic report of the new pump’s performance to Secretary McHenry and strongly recommended that the invention be installed in the frigates under construction.[3]
McHenry concurred, and the same day he notified the Secretary of the Treasury that he’d be purchasing six patent pumps for each ship. [4]  Bourke took several months to prepare the order, but by the end of May 1797, four of the pumps were on their way to Boston. What happened to the other two is not specified, but McHenry mentioned that pumps “of wood” could be made there.[5] It may be that the Navy was unwilling to bet the security of their ships on the new pump, and retained two tried-and-true chain pumps.
How long Bourke’s pumps remained on board is open to speculation. By 1801, Boston metalworker Ebenezer Leman billed the Navy for repairing Constitution’s chain pumps, and they are frequently mentioned in the ship’s logs from the 1812 period.[6] It could be that the suction pumps didn't perform as promised. An entry in the log book for September 13, 1799 mentions that two of the starboard pumps were “hoisted out” and repaired by the carpenter [7]. Luckily, the ship's crew never needed to pump for their lives.
[1]James McHenry to George Claghorn, 8 Jan. 1796, Letters Sent by the War Department Relating to Naval Matters, Jan. 3, 1794 –June 14, 1798 (M739), National Archives.
[2] Claypoole’s American Daily Advertiser (Philadelphia), 22 Dec. 1796.
[3]Thomas Truxton, John Barry, and Joshua Humphreys to James McHenry, 19 Dec. 1796, Josiah Fox Letterbook Papers, Peabody Essex Museum.
[4]James McHenry to Oliver Wolcott, Jr., 19 Dec. 1796, Secretary of the Navy Requisitions on the Secretary of the Treasury, RG45, National Archives.
[5]James McHenry to Henry Jackson, 23 May 1797, Letters Sent by the War Department…, (M739), National Archives.
[6] From notes on file at the USS Constitution Museum, taken from the Samuel Brown Papers, Massachusetts Historical Society.
[7] “Extract from log of U.S. Frigate Constitution, Captain Silas Talbot, U.S. Navy, commanding, Friday, 13 September 1799,” in Naval Documents Related to the Quasi-War Between the United States and France, vol. 4 (Washington, DC: United States Government Printing Office, 1936), 184.
发表于 2014-1-7 15:07:36 | 显示全部楼层
不要相信康威的宪法专论,这本书被国外的船迷广泛的诟病。我认为那个时代会是链式水泵和压杆水泵并用,有疑问可以参考康威的埃塞克斯号
 楼主| 发表于 2014-1-7 15:26:32 | 显示全部楼层
幽木幽木 发表于 2014-1-7 15:07
不要相信康威的宪法专论,这本书被国外的船迷广泛的诟病。我认为那个时代会是链式水泵和压杆水泵并用,有疑 ...
的确,Arming and Fitting English Ships of War 1600-1815里的英国frigate大多都是压杆和链式并用,但是我还没有找到一张宪法号的图证明这一点
    2 小时前
  • 发表于 2014-1-7 15:48:06 | 显示全部楼层
    {:soso_e132:}{:soso_e132:}
    发表于 2014-1-7 18:30:33 | 显示全部楼层
    {:soso_e149:}看不明白啊
  • 发表于 2014-1-7 18:32:22 | 显示全部楼层
    楼主资料多的眼馋啊
  • 发表于 2014-1-7 20:02:49 | 显示全部楼层
    宪法号感觉就是一个奇葩,很多配件都是比较独特的
  • 发表于 2014-1-7 21:08:14 | 显示全部楼层
    LZ的头像 另我想起了当年。
  • 发表于 2014-1-7 21:12:36 | 显示全部楼层
    不懂 围观学习吧
  • 发表于 2014-1-7 22:18:33 | 显示全部楼层
    图纸上没什么矛盾,压力泵安装图是1814年总统号的,示意在链泵前加装压力泵,可以借鉴到宪法号上。
    GMT+8, 2024-11-28 11:45 , Processed in 0.172953 second(s), 32 queries .
