TA的每日心情 | 慵懒 2020-1-16 08:06 |
diorama of a section of the HMS Victory
by Raul Guzman Jr
Scale 1/35
* My model of the HMS Victory is down below the photos of my Trafalgar diorama. In order to conserve pages, the two models are on this one page.*
My newest project is a diorama of a section of the HMS Victory during the battle of Trafalgar in 1805. It will be from the keel up to the quarterdeck. It is a formidable challenge that will force me to develop skills in figure making, modifying figures and painting. Even though it is only a section of the ship, it will be a large model since I am making it in 1/32 scale. I am using John McKay's book about the HMS Victory found in the Anatomy of a Ship series for reference and drawings. I am making a part of the aft area of the ship from about area #1 to area #15 found on pages 38 and 39 in McKay's book.
As one can tell from the photos, I made just 6 frames and clamped them together with a keel and keelson and began planking. I knew that the weight of my model would be to the side, so I added several pounds of BB's to add weight in the center. The model is therefore heavy and already weighs 18.5 pounds and is far from finished. I made some pig irons (out of maple), the well for the main mast and pumps, the shot locker and added the loose shingle ballast. I added dozens of barrels, since my research said this was the area of the hold where water was stored. The biggest barrels I made, the others I bought, stained and added "iron" hoops. The outside hull below the waterline was coppered. The last photo in this section shows the frame for the top of the hold and floor of the orlop deck.
*我的皇家海军“胜利”号模型是下面的我的特拉法尔加场景的照片。*
我的最新项目是一个1805年特拉法尔加战役期间皇家海军“胜利”号的一个部分的场景。这将从龙骨直到后甲板。这是一个艰巨的挑战,将迫使我开发在制图、修改人偶和绘画方面的技能。尽管它只是船的一个部分,也将是一个巨大的模型,因为比例为1/32。我使用的约翰•麦凯的有关皇家海军“胜利”号的书找到船舶系列的解剖,以供参考和制图。在麦凯的书的38和39页找到了我在制作的船的尾部区域的部分,从区域#1至#15。
从照片可知,我只制作6个肋骨,用龙骨和内龙骨把它们夹在一起,并开始铺板。我知道,我的模型的重量将在一侧,所以我增加几磅的BB来增加中心的重量。因此,该模型是沉重的,尚未完成已经重18.5磅。我制作了一些生铁锭(由枫木制成),以及主桅杆和泵,铅弹柜,加上松散的压舱卵石。我还加了很多桶,因为我的研究说,这里是储存水的地方。我制作了最大的桶,其余的是买的,染了色和补充“铁”箍。外部船体水线以下是铜片。这一节中最后的照片显示了作为底层舱的顶部和最下层甲板的地板的框架。 |
