查看: 7247|回复: 23
转贴Alexander Romashchenko制作“Le Requin”的过程(14)
  • 发表于 2009-8-4 00:52:12 | 显示全部楼层 |阅读模式
    接上回~~
    Wed Jun 10, 2009 5:17 pm •   Post subject:
    Making oars. First step - from square to octahedron.
    制作浆。第一步从方形到八面形。
  •  楼主| 发表于 2009-8-4 00:55:53 | 显示全部楼层
    [fbdsbsb] [fbdsbsb] [fbdsbsb]
    Thu Jun 11, 2009 7:19 pm •   Post subject:
    Making oars. Second step.
    制作浆,第二步
    Thu Jun 11, 2009 10:58 pm •   Post subject:
    For me it looks like Mantua's 12 V spar lathe. And the mill on the previous pictures is Proxxon.
    对于我来说,看起来像曼图亚的12伏圆材车床。先前的照片上的磨床是Proxxon。
    Janos
    Fri Jun 12, 2009 2:37 pm •   Post subject:
    Yes, Janos is right. It is Mantua lathe. I have also two lathe mashines - one made in Germany before World War II, second - made in USSR in 1971 Y, the best one, which can be convertable for five or six oporations - lathe, saw, fret-saw, milling and drilling.
    In our shops possible to purchase Proxxon and Dremel from Germany, some Russian or Ukrainian made and many different Chinise equipment. The last ones can be used like hummer only. Practically we have no mashines made in USA.
    是的,Janos是正确的。这是曼图亚机床。我也有两个机床 - 一个是在第二次世界大战前德国制造的,第二个是1971年苏联制造的,最好的一种,可转变五,六种操作模式 -车,锯,细锯,铣和钻。
    在我们的商店可以购买来自德国的Proxxon和Dremel,一些俄罗斯和乌克兰制造的和各式各样的中国设备。最后一个可用的像悍马。实际上我们几乎没有美国制造的机器。
    _________________
    Regards Alexander
  •  楼主| 发表于 2009-8-4 00:59:43 | 显示全部楼层
    Sat Jun 13, 2009 8:46 pm •   Post subject:
    Making oars. Third step.
    制作浆。第三步。
    Sun Jun 14, 2009 8:58 am •   Post subject:
    Making oars. End of the third step.
    制作浆。第三步结束。
  •  楼主| 发表于 2009-8-4 01:04:08 | 显示全部楼层
    Mon Jun 15, 2009 8:16 pm •   Post subject:
    Making oars. Fourth step.
    制作浆。第四步。
    Tue Jun 16, 2009 4:09 pm •   Post subject:
    Hello, Anno and Keith.
    I am not making nails by myself. Usually I use ready made nails, but I can make the nails smaller, putting above in nitrogen acid, mixed with water. Necessary to watch carefully in order do not make nails smaller than you need. In the photoes below I hope you can fined some difference.
    我没有使自制的钉子。通常我使用现成的钉子,但我可以制作小钉子,把钉子放入的氮酸,与水混合。要仔细观察,防止钉子制作的比您所需要的更小。在下面照片里我希望你能发现一些差异。
  •  楼主| 发表于 2009-8-4 01:09:26 | 显示全部楼层
    Tue Jun 16, 2009 8:09 pm •   Post subject:
    Making oars. Completion.
    Each from 20 oars consist from 5 detailes plus 14 nails plus 2 ropes.
    制作浆。完成。
    分别来自20个桨组成由5 detailes加上14个钉子加2根绳索。
    Wed Jun 17, 2009 6:50 pm •   Post subject:
    Making lashing for oars.
    用绳[链]捆绑浆
    Thu Jun 18, 2009 5:57 pm •   Post subject:
    Installation the oars and cuisine.
    安装浆和厨房
    davidcui 该用户已被删除
    发表于 2009-8-4 02:04:34 | 显示全部楼层
  • 发表于 2009-8-4 07:36:12 | 显示全部楼层
    看来我们都要去买成套的机械设备了,否则做不出精品啊。[fbdsbsb][bsbsbs]
  • 发表于 2009-8-4 08:06:20 | 显示全部楼层
    不做套材,独立的制作船模,车、铣、钳、刨、磨一个都不能少![ndsnn]
  •  楼主| 发表于 2009-8-4 08:11:11 | 显示全部楼层
    看龙马兄的“全手工制作凯撒”一贴,这老兄也有机床助力~~
  • 发表于 2009-8-4 08:21:22 | 显示全部楼层
    [vse4bb][vse4bb]偶深度中毒了[fndndn][fndndn]
    GMT+8, 2024-5-2 03:11 , Processed in 0.096163 second(s), 27 queries .
