查看: 9332|回复: 31
转贴Alexander Romashchenko制作“Le Requin”的过程(10)
  • 发表于 2009-7-31 08:45:43 | 显示全部楼层 |阅读模式
    接上回~~
    Wed Apr 15, 2009 8:39 pm •   Post subject:
    Making pulleys.
    Sheaves.
    制作滑轮
    绳轮
  •  楼主| 发表于 2009-7-31 08:48:39 | 显示全部楼层
    [fbdsbsb] [fbdsbsb] [fbdsbsb]
    Wed Apr 15, 2009 9:00 pm •   Post subject: Your cannons?
    Roma, your cannon barrels have wonderful detail. Did you buy them? Make them?
    Roma,您的炮管有漂亮纹饰。你是买的吗?制作的?
    Wiley from Texas
    Thu Apr 16, 2009 9:18 am •   Post subject:
    Hi, Wiley.
    Cannon barels hand made by method presented by Hamedal on his topic Panteleymon - Victoria.
    炮管手工制作的,方法出现在Hamedal的主题为Panteleymon – Victoria的帖子里。
    _________________
    Regards Alexander
    Sat Apr 18, 2009 7:33 pm •   Post subject:
    Making Rucks.
    Material - pear tree, D 2,0 mm and 1,8 mm.
    制作木珠
    材料 – 梨木,直径2.0毫米和1.8毫米
  •  楼主| 发表于 2009-7-31 08:52:04 | 显示全部楼层
    Tue Apr 21, 2009 7:40 pm •   Post subject:
    Making pulleys. Continious. Simple one sheave and two sheaves pulleys.
    Traditional method (any computer work).
    制作滑轮。继续。简单的单绳轮和双绳轮滑轮。
    传统方法(任何一台电脑的工作)。
  •  楼主| 发表于 2009-7-31 08:54:58 | 显示全部楼层
    Fri Apr 24, 2009 6:10 am •   Post subject:
    Hi, Roma.
    My first question about Ukrainian Championship. Will you show some pictures? Which model you presented? Result?
    Second question about blocks. I see you made sheaves for each block. Is it necessary?
    我的第一个问题关于乌克兰锦标赛。你会展示一些图片吗?哪一个是您的参赛模型?结果如何呢?
    第二个问题关于滑轮。我看你为每个滑轮制作绳轮。是否有必要?
    _________________
    Sailor S
    Fri Apr 24, 2009 6:21 pm •   Post subject:
    Hello, Sailor S.
    Thank You for your questiions.
    In Ukrainian Championship I have presented Xebeck Le Requin (without masts and riggings) and receive 98 pionts. Detailed information and photoes will be presented by Hamedal, who wisited the Championship.
    Second question is very interesting and compromising. To make sheaves for each pulley or not. First of all it depends from builder. Of caurse it is possible to make sheaves for each block, but is it necessary?
    My point of view is following:
    - Scale. If you build model at scale 1/48 and bigger better to make sheaves for each pulley exept smallest (for cannons for example).
    - Tipe of vessel. Above mantioned related to vessel like xebeck, galley, tartana which have not many (100- 150) pulleys, moustly intricate constructions. If you build big vessel like Poltava, Panteleymon-Victoria, San Felippe, etc. which have hunreds-thousands pulleys better to use method, presented by Hamedal for simple blocks. For difficult pulleys like violinas, other big blocks necessary to make sheaves.
    - Purpose of making model. For sale or for competitions or for pleasure.
    It will be very interesting to hear opinion others members of MSW about this question.
    感谢您的问题。
    在乌克兰锦标赛我推出Xebeck Le Requin(不包括桅杆和索具),获得98分。详细的资料和照片将由Hamedal(冠军获得者)介绍。
    第二个问题是非常有趣和折中。为每个滑轮制作绳轮与否。首先,它取决于制作者。当然可以给每个滑轮制作绳轮,但是否有必要?  我的观点是如下:
    -比例。如果您在制作1/48比例或更大的模型,最好每个滑轮制作绳轮,除了最小的(例如为大炮的)。
    - 船的型式。上述提到的有关船只像小型三桅船,大划桨船,tartana已经没有多少(100 - 150)滑轮,moustly错综复杂的结构。如果您想制作大型船只象Poltava(波尔塔瓦),Panteleymon-Victoria,San Felippe(圣菲利普)等有成百上千个滑轮,对简单的滑轮,最好使用Hamedal介绍的方法。对象小提琴类音栓一样的复杂滑轮,其他大滑轮需要制作绳轮。
    -制作模型的目的。为了出售,或参赛,或寻找乐趣。
    听取其他MSW成员关于这个问题的意见,将是非常有趣的。
    _________________
    Regards Alexander
    Sat Apr 25, 2009 6:31 pm •   Post subject:
    Making violines pulleys.
    制作小提琴一样的滑轮
  •  楼主| 发表于 2009-7-31 08:58:29 | 显示全部楼层
    Sun Apr 26, 2009 4:33 pm •   Post subject:
    Making violines pulleys. Continious.
    制作小提琴一样的滑轮,继续
    Sat May 02, 2009 11:23 am •   Post subject:
    Pulleys. Finishing.
    滑轮,完成
  •  楼主| 发表于 2009-7-31 09:02:45 | 显示全部楼层
    Sat May 02, 2009 9:04 pm •   Post subject:
    Making Halayrd blocks.
    制作帆桁[吊杆]吊索滑轮
  •  楼主| 发表于 2009-7-31 09:03:46 | 显示全部楼层
    Sat May 02, 2009 10:05 pm •   Post subject:
    Ah you're the devil of a man Roma
    Those halyard blocks are whoppers are they not? Nice work!
    啊,你是魔鬼男人,Roma 这些帆桁[吊杆]吊索滑轮,他们是不是牛奶巧克力球?细致的工作!
    Keith.
    Sun May 03, 2009 9:48 am •   Post subject:
    Thank You, Keith.
    It's big pleasure to hear such words from man who not only understand, but build beautiful models.
    Just now I have finished the blocks, made smallest Halayrd blocks.
    从不仅仅是理解,而且制作漂亮模型的男人这里听到这样的话很高兴。  刚才我已经完成了滑轮,制作最小的帆桁[吊杆]吊索滑轮。
    发表于 2009-7-31 09:34:06 | 显示全部楼层
    做的真不错,够细至,目标!!!!!!!!!!!!!
  • 发表于 2009-7-31 09:45:47 | 显示全部楼层
    这种工业化的制作是我们不能达到的,只有看看了。[bsbsbs]
    5 小时前
  • 发表于 2009-7-31 10:50:44 | 显示全部楼层
    怎么不能~不就几个设备嘛~买来就好了嘛~
    GMT+8, 2024-11-28 15:07 , Processed in 0.203935 second(s), 27 queries .
