TA的每日心情 | 慵懒 2020-1-16 08:06 |
Dunkerque
by Ted Bunn
1/400
Heller
I usually prefer waterline ships, which meant I had to cut the hull on my Dunkerque kit. I accomplished this by using Dymo labeling tape as a guide for my scriber to start with and then finishing the cut with a hand saw. I used .040 Evergreen sheet stock for a waterline plate.
Since there is no dedicated PE set for this kit, I used GMM's generic naval set for the railings and various other small parts. Bits and pieces from my PE spares box was also used here and there.
The Loire floatplane and catapult that came with the kit was way too clunky and had to go, so it was replaced with L'Aresenal's fine 1/400 Catapult cuirasses Francais set. This is actually a small kit itself consisting of two PE catapults and two resin Loire floatplanes with PE struts and rudders. I goes together very nicely as well. Thanks to Tony Bunch and Jacques Druel for tracking down the set and getting it to me.
Additional stanchion supports were made from Evergreen rod. Rigging was done with stretched sprue and the water was made from Golden heavy gel medium. The model was lightly weathered overall with MiG pigments.
“敦刻尔克”号
制作者:泰德•邦恩
比例:1/400
套材:海勒
我通常喜欢水线船,这意味着我不得不切割我的“敦刻尔克”号套材的船体。本人完成这个首先Dymo标记签带作为划线器的向导,然后用手工锉休整切割面。我用0.040现成的薄木板作为水线板。
由于这个套材没有专门的蚀刻件,对栏杆和其他各种小零件,我于使用GMM的通用海军套。在我多余的蚀刻件盒里的零碎也被用来在这里和那里。
套材附带的Loire水上飞机和弹射器太笨重了,舍去,,所以改为L'Aresenal's优良的1/400 L'Aresenal's 装甲法琅件。这实际 上是一个小套材,本身包含两个蚀刻弹射器和两个带蚀刻支架和方向舵的树脂Loire水上飞机。我协调的非常不错。感谢Tony Bunch和Jacques Druel找到这套东西并把它给我。
增加的立柱支撑是木棒制作的。索具是用拉长的熔丝做的和水是由Golden重凝胶。该模型是米格颜料轻微风化。 |
