查看: 2102|回复: 3
“HMAS Australia 澳大利亚”号 - 场景模型
  • 发表于 2009-7-25 15:48:01 | 显示全部楼层 |阅读模式
    HMAS Australia
    by Min Hin Chong
    1/700 HMAS Australia (Combrig)
    The model depicts the Australia as she appears in 1941.
    The following modifications were made to the kit:
        * Deletion of 20 mm gun tubs on turrets, fantail and bridge wings. The Australia did carry these weapons, but I couldn't work out their location on the photos of the ship in this time period.
        * Replacement of resin anchors with PE anchors from Tom’s Modelworks
        * Moulded on anchor chains removed and replaced with miniature chain
        * Doorway cut into breakwater
        * Periscopes added to main gun turret cheeks from strip styrene
        * Main gun barrels replaced with turned metal items from Clipper Models
        * Multiple Deck vents added to main deck, scratch built from styrene rod
        * Multiple photo-etch doors, ladders and hatches added to superstructure
        * Bridge wing supports scratch built from styrene and photo-etch from White Ensign Models
        * Details such as binoculars and compass from the spares box added to open bridge.
        * Splinter mattresses scratch built form styrene and added to upper bridge level, area behind main mast and director tower
        * Masts constructed from brass wire. WEM PE added
        * Type 286 radar added to mainmast from Tom’s Modelworks PE set
        * Scratch built searchlight platforms adjacent to fore funnel. Searchlights from the spare’s box
        * Ammo boxes from spares box added to main deck.
        * Additional pair of ship’s boat’s added from spare’s box.
        * Photo-etch boat chocks and oars from White Ensign Models added to boats.
        * Splinter shields around 4 inch AA mounts scratch built from styrene
        * Vision slit covers added to 4 inch AA turrets
        * Whistle platform added to fore funnel from White Ensign Models
        * Funnel piping redone with styrene rod
        * Funnel cap grills modified from White Ensign Models PE
        * Cranes scratch built from Styrene tube, resin and PE from White Ensign Models (Those cranes are huge, I used 1/600 Repulse PE cranes!)
        * Torpedo tube housing scratch built form styrene
        * Aircraft catapult from White Ensign Models PE.
        * Walrus aircraft from Trumpeter. White Ensign Models PE added.
        * Pompoms replaced with resin and photo-etch from White Ensign Models
        * Aft Search light platforms constructed from WEM PE. Searchlight from the spares box.
        * Boat davits from Hasegawa PE.
        * PE railing from White Ensign Models.
        * Ship and aircraft rigged with paintbrush bristles for heavy cable and Uni-Caenis fly tying line for finer lines.
    “HMAS澳大利亚”号
    制作者:Min Hin Chong
    比例:1/700
    套材:Combrig
    该模型描述了澳大利亚,她在1941年现身。
    下面是对模型套材的修改:
         * 删除了20毫米炮炮塔上的盆,船尾甲板和桥翼。“澳大利亚”号没有携带这些武器,但是在这段时间我无法解决他们在船的照片上的位置。
         * 用Tom’s Modelworks的蚀刻锚更换了树脂锚
         * 去掉模制的锚链,取而代之的是小链条
         * 通道切割成防波堤
         * 潜望镜添加到主炮塔两侧的塑料带
         * 主炮管改为Clipper Models的金属件
         * 多个舱口添加到主甲板上,用苯乙烯棒自制的
         * 多个蚀刻的门、梯子和舱口添加到上层建筑上
         * 桥式支架用苯乙烯和White Ensign Models的蚀刻片自制的
         * 配件盒里的望远镜和指南针等细节添加到敞开的舰桥上
         * 分裂床垫用苯乙烯自制并加到舰桥梁上层,主桅和主塔后面的地方
         * 桅杆用铜丝制作,添加WEM的蚀刻件
         *  Tom’s Modelworks的蚀刻件,286型雷达添加到主桅上
         * 自制的探照灯平台毗邻前烟囱,探照灯是配件盒里的
         * 把配件盒里的弹药箱添加到主甲板上
         * 把配件盒里的附加的一对小艇加上
         * 把White Ensign Models蚀刻船垫和桨增加船上
         * 用苯乙烯自制分裂盾周围的4英寸机炮组合座
         * 观测窗盖添加到4英寸机炮塔上
         * White Ensign Models的汽笛平台添加到前烟囱
         * 烟囱用苯乙烯棒装饰
         * 烟囱罩格栅用White Ensign Models的蚀刻件改进
         * 用苯乙烯管材,树脂和White Ensign Models的蚀刻件自制起重机(这些起重机是巨大的,我用1/600 Repulse蚀刻起重机!)
         * 用苯乙烯自制鱼雷发射管罩
         * 飞机弹射器是White Ensign Models的蚀刻件
         * 号手的海象飞机加White Ensign Models的蚀刻件
         *  对空速射炮用树脂和White Ensign Models的蚀刻件取代
         * 后部探照灯平台用White Ensign Models的蚀刻件制作,探照灯是配件盒里的
         * 吊艇杆是长谷川的蚀刻件
         * 蚀刻的栏杆是White Ensign Models的
         * 船舶和飞机的牵索用画笔刷毛来体现沉重感,而旗线用细线条。
  •  楼主| 发表于 2009-7-25 15:49:17 | 显示全部楼层
    [fbdsbsb] [fbdsbsb] [fbdsbsb]
  • 发表于 2009-7-25 16:53:11 | 显示全部楼层
    [vse4bb]改造的干净利落,好手艺[fbdsbsb]
    huohu721 该用户已被删除
    发表于 2009-8-14 13:24:33 | 显示全部楼层
    GMT+8, 2024-5-5 18:25 , Processed in 0.082235 second(s), 25 queries .
