查看: 5370|回复: 16
希腊帆船“Varkalas”
  • 发表于 2009-7-19 08:57:08 | 显示全部楼层 |阅读模式
    Varkalas
    It was a Greek type of vessel which been used in the islands of the Eastern Aegean Sea in the 19th century. Its name must be relative to "Barque" which is mentioned and in the seamanship of other countries. The main characteristic was the decorated counter in stern post and the straight up cutwater. It was usually rigged as "Bratchera" (two large square sails) and later as "Radopsathi" (one large square sail in foremast and a gaff sail in aft mast ).It was used as a commercial transportation vessel.In our days we see only small "Varkalas" vessels and all the boats with counter in stern are usually called so. The specific model is rigged as "Radopsathi". The model is scratch build (and everything around it)and it’s dimensions are 50 cm long (from cutwater to stern) 18,5 cm width and 57 cm in high.It's scale is 1:30. Don’t see it as a diorama. I just made a stand for this no sail vessel.
    在19世纪,这是一个被用于爱琴海东部群岛的希腊船型。其名称必定与其他国家的船员提到的“三桅帆船”有关。其主要特点是带装饰的船尾柱突出部和笔直的船头破浪处。通常它的帆具是“Bratchera”形式(两个大横帆),后来成为“Radopsathi”形式(前桅一个大横帆和后桅一个上缘斜桁帆)。它被用做为商业运输船。在我们的时代,我们只能看到小“Varkalas”船和所有带船尾突出部的通常也称之为"Varkalas"的船只。具体的模型是“Radopsathi”形式的帆具。该模型是从零开始制作的(包括它周围的一切),它的尺寸是50厘米长(从船头破浪处到船尾),18,5厘米宽,57厘米高。它的比例是1:30。不能把它看作是一个场景。我只为这只没有帆的船做了个船台。
  •  楼主| 发表于 2009-7-19 08:59:18 | 显示全部楼层
    [fbdsbsb] [fbdsbsb] [fbdsbsb]
  •  楼主| 发表于 2009-7-19 09:01:31 | 显示全部楼层
  •  楼主| 发表于 2009-7-19 09:04:07 | 显示全部楼层
  •  楼主| 发表于 2009-7-19 09:05:35 | 显示全部楼层
  • 发表于 2009-7-19 09:42:15 | 显示全部楼层
    制作精致,船壳铺的非常公正。学习了。[dnsiohf8][vse4bb][fnbebeb]
  • 发表于 2009-7-19 09:43:42 | 显示全部楼层
    [vse4bb][vse4bb][vse4bb]好资料。
  • 发表于 2009-7-19 11:45:13 | 显示全部楼层
  • 发表于 2009-7-19 13:04:06 | 显示全部楼层
    好漂亮,赞一个[vse4bb]
    昨天 21:25
  • 发表于 2009-7-19 14:17:29 | 显示全部楼层
    真的很棒!![vse4bb][vse4bb]
    GMT+8, 2025-3-3 19:59 , Processed in 0.097134 second(s), 30 queries .
