TA的每日心情 | 慵懒 2020-1-16 08:06 |
by Heiko Schittek
1/700 Gremyashchy (DML)
This is the Sovremenny Class destroyer "Gremyashchy" (Thunderous). It is one of the two Sovremennys assigned to the Northern Fleet and will be part of a Russian surface action group that I plan on completing someday.
The ship was built out of DMLs "Russian Sovremenny Class Destroyer" kit. I had originally thought that the PE parts that came with the kit were sufficient but I changed my mind once I found that there were no PE parts supplied for the foremast. I therefore used GMM's excellent PE alternative and replaced almost every part that came with the kit except for a large number of railings which were also taken from other previously used sets that had left over railings.
Other than that, it was a good kit to build with the usual minor things that need to be corrected. However, the fact that all superstructures are already part of the upper hull made it more difficult to paint the decks. Further detailing is done with copper wire. The rigging is made out of stretched sprue. The colors used are from WEM, as well as various other companies. The water is modeled with what has now become my favorite method: acrylic paint and 3D model paste on a glass plate.
模型套材供应商:DML
制作者:Heiko Schittek
比例:1/700
这是现代级驱逐舰“Gremyashchy ”号(雷鸣)。它是分配到北方舰队的两艘现代级驱逐舰之一并且将是我计划有朝一日完成的俄罗斯水面舰艇的部分。
该模型由DML的“俄罗斯现代级驱逐舰”套件制作。我原本以为,PE部分附带有足够的工具,但我一旦发现,对前桅没有提供任何PE零部件,就改变了主意。因此,我利用GMM的出色的PE替代,并取代了几乎每一个部分,除了套件附带的大量的栏杆,其中还采取了其他以前使用过的材料,已经离开了栏杆。
除此之外,这是一个很好的套材,制作中通常较少需要加以纠正。然而,事实上所有上层建筑已经是上层船体的部分变得更加困难涂漆。进一步用铜线做细节。索具做出拉紧状。使用的油漆是WEM,以及其他公司。水是采用已成为我最喜欢的方法模仿的:丙烯酸涂料和三维模型贴在玻璃板上。 |
