查看: 2970|回复: 8
“Kerch”号 - 场景模型
  • 发表于 2009-6-9 15:27:38 | 显示全部楼层 |阅读模式
    模型套材供应商:Combrig
    比例:1/700
    制作者:Joerg Kuhnert
    The navy at the Nikolayev shipyard between 1971 to 1977 built seven units of Nikolayev class that were referred by NATO as the Kara Class. The Kara class, project 1134B "Berkut B", is a gas turbine powered vessel. The ships were in service mainly with the Black Sea Fleet, but were also served in the Mediterranean Sea and in the Pacific.
    The large exhaust for the gas turbine dominates. On the quarterdeck there was a landing platform for ASW helicopters, the hangar is partially embedded in the deck.
    Later vessels have an additional porch off the bridge and other platforms and Radomes on main fwd structure
    Technical Data
    Length 173.4 m
    Width 18.5 m
    Draft 5.74 m
    Turbine Drive COGAG with 120,000 horsepower on two shafts
    Top speed: 34 knots
    Armament
    • 2 x 4 URK-5/SS-N-14 Rastrub / ASW rocket torpedoes
    • 2 Shtorm SAM system (80 V-611/SA-N-3 goblet)
    • 2 Osa-M SAM system (40 4M-33/SA-N-4 Gecko)
    • 2 x 2 76.2mm/59cal AK-726 multipurpose DP guns
    • 4 x 6 30 mm AK-630 AA Gatling cannons
    • 2 twelve tube throwers RBU 6000, Thrower 2 RBU 1000
    • 2 x 5 533 mm torpedo tubes
    • 1 helicopters Kamov Ka-25/27
    The build required a lot of essential research , a willingness to re-work and convert . I supplemented and replaced many part with Photoetch parts. . Highly recommended are the Enamels of WEM for the modern Russian fleet.
    1971年至1977年期间,海军在尼古拉耶夫造船厂建成七艘被称为北约作为“卡拉”级的尼古拉耶夫级。卡拉级,项目1134B “金雕B ”的,是一种燃气涡轮动力的船只。该舰主要是在黑海舰队服役,但也是出现在地中海和太平洋舰队中。
    天然气涡轮机的大排气口在舰体的中间地位。在后甲板上有一个反潜直升机的着陆平台,飞机库部分嵌入甲板。后期的舰只还增加了门廊、桥和其他平台和主结构上的雷达罩。
    技术数据
    长度:173.4米
    宽度:18.5米
    吃水:5.74米
    汽轮机驱动:COGAG 120,000马力,双轴
    最高时速:34节
    武器装备:
    • 2 × 4 URK-5/SS-N-14 Rastrub /反潜火箭鱼雷
    • 2 Shtorm 地空导弹系统( 80 V-611/SA-N-3高脚杯)
    • 2奥萨物的SAM系统( 40 4M-33/SA-N-4壁虎)
    • 2 × 2 76.2mm/59口径 AK - 726多用途DP炮
    • 4 × 6 30毫米的AK – 630防空加特林炮
    • 2 12管RBU 6000,2 RBU 1000投掷器
    • 2 × 5 533毫米鱼雷管
    • 1架卡莫夫Ka-25/27直升机
    制作需要大量的基本研究和改造。本人补充和更换了许多蚀刻件。强烈推荐WEM的珐琅漆用于现代俄罗斯舰队。
  • 发表于 2009-6-9 15:34:14 | 显示全部楼层
    俄罗斯舰艇确实漂亮。不过这套模型细节太少,有点单调。[dbsebes]
  • 发表于 2009-6-9 15:37:20 | 显示全部楼层
    漂亮~~水做的尤其仿真~
    yellowhost 该用户已被删除
    发表于 2009-6-9 17:05:42 | 显示全部楼层
  • 发表于 2009-6-9 17:57:11 | 显示全部楼层
    [vse4bb]最近场景模型好多。
  • 发表于 2009-6-9 18:32:42 | 显示全部楼层
    喜欢场景[vse4bb],谢谢楼主[fnbebeb]
    huohu721 该用户已被删除
    发表于 2009-8-14 13:41:23 | 显示全部楼层
    LIHAO 该用户已被删除
    发表于 2012-6-22 10:39:36 | 显示全部楼层
    zwf 该用户已被删除
    发表于 2012-6-24 22:01:32 | 显示全部楼层
    GMT+8, 2024-11-28 10:52 , Processed in 0.153541 second(s), 28 queries .
