查看: 2933|回复: 8
SHARKE 1711欣赏
  • 发表于 2009-5-13 08:37:15 | 显示全部楼层 |阅读模式
    SHARKE
    Historical background of the ship
    The British cutter SHARKE was built in 1711 at the Deptford dockyards on the Thames River. She was designed for speed. With her large sail area and because of her shallow draught and minimal tonnage she could follow smugglers anywhere, even up shallow rivers and over dangerous shoals. With her ten pounder cannons she could easily fight any small boat.
    The ship model, photos, description and dimensions
    The model is a somewhat smaller decoration object compared with the other ship models, well suitably as maritime symbol under spatially more restrained conditions. The extensive sails clearly make for the impression of speed and mobility.
    The very finely worked model of the cutter is 1 : 50 scale. Length is 84 cm, width 27 cm, height 61 cm.
    电脑翻译
    历史背景:
    船舶英国刀SHARKE建于1711年在德普特福特船坞的泰晤士河。她设计的速度。她的大帆面积和因为她浅吃水和最小吨位她可以随时随地后续走私,甚至浅水河流和险滩。与她的10磅炮,她可以很容易地打击任何小船。
    船舶模型,照片,描述及尺寸:
    该模型是一个较小的装饰物件与其他船舶模型,以及适当的海洋空间更象征根据约束条件。广泛帆作出明确的印象是速度和机动性。 比例:1/50
    长:84cm
    宽:27cm
    高:61cm
  •  楼主| 发表于 2009-5-13 08:41:21 | 显示全部楼层
    呵呵!和扬帆的金牛号同船型,同属于英国单桅纵帆船船型。
    全身照:
  •  楼主| 发表于 2009-5-13 08:44:49 | 显示全部楼层
    细节
  • 发表于 2009-5-13 08:50:48 | 显示全部楼层
    又是一条快速船,这在当时还是很先进的。外观也很壮观。[vse4bb] [vse4bb] [vse4bb]
  • 发表于 2009-5-13 08:57:20 | 显示全部楼层
    眼谗的很~~[fbdsbsb]
  • 发表于 2009-5-13 10:16:20 | 显示全部楼层
    看着像国内的活,谁家又出新套才吗?
  •  楼主| 发表于 2009-5-13 19:10:39 | 显示全部楼层
    国外的,非国内的,看着像套材作品[ndbbnd]
  • 发表于 2010-12-18 21:59:15 | 显示全部楼层
    感觉一般。
    咖啡人生-76 该用户已被删除
    发表于 2014-5-23 14:55:48 | 显示全部楼层
    GMT+8, 2025-2-20 16:34 , Processed in 0.080643 second(s), 28 queries .
