查看: 3298|回复: 4
国外精品蒸汽机 Graupner 两缸 船用蒸汽机
  • 发表于 2009-4-29 17:30:45 | 显示全部楼层 |阅读模式
    Graupner 2 Cylinder Marine Steam Engine
    Product information
    The steam engine is suitable for powering ship models of the paddler type, as well as those driven by marine propellers. In the latter case two gear wheels and a shaft will be required additionally, which are not included in the kit proper. The various assembly groups of the steam engine have to be assembled and bolted together, respectively, as per instructions.
    All parts come soldered where necessary. The boiler is heated with butane gas. Gas consumption approx. 20 g for an engine run of approx. 25 minutes.
    The kit contains:
    A 320cm3 brass boiler of 55 mm diameter, length 135 mm, with inspection glass showing water level. Boiler house with two gangways, spring-loaded safety valve, plastic tube serving to join the steam piping from boiler to aggregate, brass gas tank with regulator valve and a standard EURO fill-up valve. Two stationary double-acting brass cylin- ders, 50 mm diameter flywheel, self-starting in either direction. Drive shaft diameter 4 mm. Steam-jet oiler fully reversible running forward or backward, with infinitely variable speed control. Hook-up to R/C control via reversing handle.
    Specification
    Weight, cpl. 1 kg
    Incl. boiler water filling 1.3 kg
    Base plate with boiler and gas tank
    Length 180 mm
    Width 110 mm
    Height 130 mm
    Weight 600 g
    Aggregate Length 115 mm
    Width 90 mm
    Height 50 mm
    Weight 400 g
    Price: £325.99 (Including VAT at 15%)
  • 发表于 2009-4-29 18:41:48 | 显示全部楼层
    Graupner 2缸船舶蒸汽机
    产品信息 paddler型适合动力船舶模型的蒸汽机,以及推动船舶螺旋桨。在后一种情况下,将需要增加两个齿轮和轴,这不包括在本套件中。蒸汽机的各个组件已经分别按操纵指南组装并用螺栓固定在一起。
    所有零件必须焊接。锅炉用丁烷气加热。发动机运行25分钟约消耗气体20克
    该套件包括:
    一个直径55毫米,长度135毫米,320立方厘米的黄铜锅炉;带观察水位的玻璃显示。带双通道的锅炉,弹簧式安全阀,塑料管加入从锅炉到Aggregate的蒸汽管道,带调节阀的黄铜储气罐和一个标准的欧洲填充阀。两个固定双向黄铜汽缸, 50毫米直径的飞轮,可在任一方向自启动。直径4毫米的传动轴。蒸汽喷射油商完全可逆运行向前或向后,带无限可变速度控制。通过回转手柄连接到R / C控制。
    规格
    重量:cp1 1公斤
    锅炉水灌装一点三公斤
    底板与锅炉和煤气罐
    长度:180毫米
    宽度:110毫米
    高度:130毫米
    重量:600克
    Aggregate长度:115毫米
    宽度:90毫米
    高度:50毫米
    重量:400克
    价格: £ 325.99英镑(包括15%增值税)
    发表于 2010-2-15 09:12:19 | 显示全部楼层
    谢谢,收藏了。:victory:
    liuxiaodongdd 该用户已被删除
    发表于 2010-8-21 10:08:43 | 显示全部楼层
    lzg1015 该用户已被删除
    发表于 2012-5-22 15:51:45 | 显示全部楼层
    GMT+8, 2024-5-8 12:48 , Processed in 0.106477 second(s), 26 queries .
