查看: 4636|回复: 7
Man-of-War, 64-Gun British Ship(二)
  • 发表于 2009-3-20 10:50:31 | 显示全部楼层 |阅读模式
    17th century british ship - Man-of-War, 64-Gun British Ship
    17世纪的英国船
    The model is 100% scratch built, made out of chestnut wood, custom made, 1-of- a-kind…
    The scale of this ship is 1/96 so it would be 168’ long x 42’wide, and draws 21’ of water.  The model is 27” long x 12” wide, and 25” high mid-ship.  And 5 different deck levels, plank-on-frame construction.  Total work hours on the model, 1,175, and about 10,000 pieces.  About 61’ of rigging.
    该模型是100%从零开始制作的,用栗木制成,定制, 1中,一类的规模……
    这艘船的比例是1:96,所她有168呎长,42呎宽,吃水21呎。该模型是27吋长,12吋宽,25吋高中等船。她有五层不同层面的甲板,木质框架结构。模型的总工作时间1,175小时,和大约10,000件零件。大约61呎索具。
    Model by Den Holmes
    制作者:Den Holmes
    On sale (one in stock) $12,000
    售价:$ 12,000
    转载自:densmodelships.com
    Mast and rigging Plan
    [localimg=400,300]19[/localimg]
    由于涉及许多专业名称,我在翻译的时候不能完全把握,对于翻译错误,欢迎业内人士拍砖,指正。谢谢!
    Part 2 Mast
    第二部分 桅杆
    Here is some photo of the mast that went on my British Ship model ..
    这是我的英国船上的桅杆的照片
    All the standing figging (black) was laid up on my Ropewalk.
    Bowsprit
    船首斜桅
    Bowsprit Side view of the bowsprit in work progress, not finished.
    制作中的船首斜桅侧视图,尚未完成。
    Bowsprit Gammoning: Shows the bowsprit cleats, gammon cleats, gammoning knee, gammoning, wooldings, and bowsprit fairlead saddle.
    船首斜桁猪腿:斜桅夹板,猪腿夹板,猪腿膝关节,猪腿,绞扎绳索,及鞍状的导索器。
    Bowsprit Blocks Side view of the bowsprit: Shows the Fore Mast stay block, and the bobstay blocks.
    船首斜桅的滑轮侧视图:显示了前桅系留滑轮和斜桅支索滑轮。
    Under the Bowsprit Top: Shows the under side of the bowsprit top, the trestle-trees, and the cross-trees. Shows the standing rigging of the spritsail yard block, and the spritsail yard brace blocks.
    船首斜桅桅楼:船首斜桅桅楼的下侧,树状支架,树状十字。斜桁帆静索的滑轮,及紧斜桁帆滑轮。
    Bowsprit Top: Close-up of the bowsprit top, this is where the bowsprit shrouds will be attached to the dead-eyes.
    船首斜桅桅楼:船首斜桅桅楼的近摄,船首斜桅索将附着在“死眼”。
    Bowsprit Blocks: Shows the heart block, where the Fore-main stay will connect.
    船首斜桅滑轮:心状滑轮,连接前主系留。
    Side View of Bowsprit: Shows the bowsprit setting up with the blocks stropped to it. Still in work progress.
    船首斜桅侧视图:仍在制作中。
    Top Spritsail Yard: Shows some of the blocks that are stropped over the top spritsail yard. These are called the lift blocks, and under the yard is the clue garnet block.
    顶斜桁帆桁:一些环绕在顶斜桁帆桁的滑轮。这些被称为升降滑轮,桁下方的是clue garnet 滑轮。
    Spritsail Yard top view of the bowsprit and spritsail yard blocks, almost ready to be rigged.
    船首斜桅的顶视图和斜桁帆桁滑轮,方便装配帆和索具。
    Spritsail Yard Blocks: This photo shows under the spritsail yard and the blocks stropped over the yard and bowsprit. Shows the lift blocks, tie blocks, bobstay blocks, and the spritsail sheet blocks.
    斜桁帆桁滑轮:照片显示斜桁帆桁的下方,环绕其上的滑轮和船首斜桅。显示了升降滑轮,系滑轮,斜桅支索滑轮,及斜桁帆滑轮。
    Fore-Stay Block: Shows the fore-stay block, spritsail blocks, and the bobstay blocks.
    前系留滑轮:显示了前系留滑轮,斜桁帆滑轮,及斜桅支索滑轮。
    Bowsprit Blocks: This shows some of the blocks that are put over the Bowsprit and spritsail yard. Made out of Chestnut wood, and all the blocks and cleats are made out of Cherry wood.
    船首斜桅滑轮:显示了放置在船首斜桅和斜桁帆桁上的一些滑轮。所有的滑轮是栗木做的,而夹板是樱桃木做的。
    Spritsail: View of the back of the furled sail.
    斜桁帆:卷起的帆的后视图。
    Spritsail Yard: Shows the furled sail on the spritsail yard.
    斜桁帆桁:显示了斜桁帆桁上的卷拢的帆。
    Spritsail Halliards: Shows some of the rigging on the spritsail.
    斜桁帆挂索:显示了斜桁帆上的索具。
    Bowsprit Topsail: The topsail is bent to the bowsprit topsail yard.
    船首斜桅上桅帆:在船首斜桅上桅帆桁上弧形的上桅帆。
    Bowsprit Topsail Yard: Shows the top of the bowsprit, shrouds, foot ropes, lift blocks, sheave hole.
    首斜桅上桅帆桁:显示了船首斜桅,上下连接索,脚绳,升降滑轮,滑轮洞。
    Bowsprit: Shows the back of the bowsprit.
    船首斜桅:船首斜桅的背面。
    [ 本帖最后由 old_cobra 于 2009-4-26 16:04 编辑 ]
  •  楼主| 发表于 2009-3-20 10:59:28 | 显示全部楼层
    Main Mast
    主桅
    Jeer Blocks, Lower Yard: Shows the jeer blocks stropped over the lower yard in between the cleats. Shows the trestle-trees, cross-trees, and the eye bolts for the futtock shrouds. On the lower yard it shows the leech line blocks on top, and the clue garnet and topsail sheet blocks on the bottom of the yard.
    Jeer滑轮,下桁:夹板之间环绕在下桁上的Jeer滑轮。树状支架,树状十字及为连接上下桅的铁索的眼螺栓。在下桁上,显示了桅楼上的帆端上拉索滑轮,clue garnet,及桁下部的上桅帆滑轮。
    Main Mast Parre:l Close-up of the main mast parrel, mast cheeks, and the fish along the side of the lower mast. Still in working progress.
    主桅索箍:主桅索箍的近摄,桅颊,及沿着下桅旁边的接合板。仍在制作中。
    Main Mast Head: Shows the dead-eyes being put on the topmast shrouds, and the lanyards being reeved through the dead-eyes. Note: Its best to put the lower shrouds on first, before the top shrouds.
    主桅顶端:显示了放置在中桅上下桅连接处的“死眼”,穿过“死眼”缠绕的挂绳。注意:最好在
    Main Mast Top Looking down on the main mast top, you can see through the lubber hole, and the dead-eyes. Shows the lift blocks, jeer blocks, leech line blocks, eye-lets for the jack-stay, boom irons, and the cleats on the lower main mast yard.
    主桅杆顶向下看去,在主桅杆桅楼,你可以看到穿过水手孔,和死眼。显示了升降滑轮,jeer滑轮,帆端上拉索滑轮,为了支索的鸡眼,吊杆,及下主桅桁上的夹板。
    Main Topsail Yard: Shows the blocks on the topsail yard.
    主上桅帆桁:显示了上桅帆桁上的滑轮。
    Main Top Mast Shroud: This photo shows the main top of the Main Mast. Shows the start of the topsail mast shroud being rove through the dead-eyes.
    主桅楼桅杆:照片显示主桅的主桅楼。显示了上桅帆始端穿过“死眼”。
    Back of Sail: Shows the back of the sail.
    帆的背面
    Furled Sail: Shows the Main Mast with the course sail furled, shows the lower shrouds put over the mast head.
    卷起的帆:显示了带卷帆的主桅,和安置在主桅头的上下桅连接索。
    Back of Main Mast: Shows the aft side of the Main Mast.
    主桅的背面
    Main Mast: Front view of the Main Mast.
    主桅的前视图
    Top Mast Shroud: Shows the shrouds, sails, leech line blocks.
    桅楼:显示了上下桅连接索,帆,帆端上拉索滑轮。
    Dead-eyes: Shows the laniards on the dead-eyes.
    死眼:显示了“死眼”上的挂索。
    Main Shrouds: Shows the Main-topsail with the wind in the sails. I mix water, Elmers glue, and a little Antique white Acrylic paint together. Then I dip the sail in the mixture, then take it out and lay it on a piece of tin the size of the sail, then shape it into a sail, then put it in the oven on warm until hard.
    主桅上下桅连接索:显示了主上桅帆,受风的帆。我把水、埃尔默胶、少量的白漆混合。然后把帆浸入混合液中,然后取出,放在与帆同尺寸的锡板上,塑造成形,放在温暖的的地方直到干硬。
    Main Topsail: Shows the topsail added to the Main Mast. This British ship model will have 11 sails on the masts, it took a total of 56 hours just on the sails alone.
    主上桅帆:显示了主桅上的上桅帆。这艘英国船的主桅上有11面帆做这些帆花费了56个小时。
    Side View Back view of the Main mast
    主桅的后侧视图
    Main-Shrouds: Shows the shrouds put over the mast head.
    主桅上下桅连接索:安置在主桅头的上下桅连接索。
    Main Topsail Yard: Shows the blocks that are stropped over the topsail yard, tie blocks, quarter blocks, leech line blocks, boom irons, and the lift blocks. Note the brace blocks, are not put over the yard arm as of yet. Shows the start of the topsail shroud being put over the topsail mast top.
    主上桅帆桁:显示了环绕在上桅帆桁上的滑轮、系滑轮、转角滑轮、帆端上拉索滑轮、吊杆、,和升降滑轮。注意:支撑滑轮不是安放在桁臂上。上桅帆的始端安置在上桅帆主桅桅楼上。
    Sail-Cloth: This sail-cloth is linen, called Super Muslin, and can be purchsed at Walmart.
    帆布:帆布是亚麻的,称为超级细布,能在沃尔玛买到。
    [ 本帖最后由 old_cobra 于 2009-4-26 16:12 编辑 ]
  •  楼主| 发表于 2009-3-20 11:08:20 | 显示全部楼层
    Mizzen mast
    后桅
    Lateen Yard & Cross-Jack Yard: Shows the blocks stropped to the Mizen Mast. On the upper part of the lateen yard, is the peak, middle, and throat brial block. On the lower part of the lateen yard is the foot brial blocks. Also shows the Mizen parrel for the lateen yard.
    三角帆桁和后桅下桁:显示了滑轮环索到后桅上。在三角帆桁上半部分是高、中和throat brial滑轮。三角帆桁的下半部分是foot brial滑轮。及固定三角帆桁的后桅索箍。
    Cross-Jack Yard: Close-up of the Mizen top, shows the stirrup where the foot-rope will reeve.
    后桅下桁:后桅桅楼的近摄,显示了穿过脚绳的蹬。
    Mizen Mast Top
    后桅桅楼
    Mizen Mast Parrel: Shows the parrel on the lateen yard, and the brial blocks on the lateen yard. Shows the lower Mizen mast cheek, trestle-trees, and cross-trees.
    后桅索箍:显示了三角帆桁上的索箍,和三角帆桁上的brial滑轮。后桅颊、树状支架好树状十字。
    Cross-Jack Yard Blocks: Shows the cross-jack yard and the blocks that are stropped over the yard, the slings, topsail sheet block, leech line block, and the lift blocks. Note, the brace blocks have not been put over the yard arm, as of yet.
    后桅下桁滑轮:显示了后桅下桁和环绕在桁上的滑轮、吊索、上桅帆滑轮、帆端上拉索滑轮和升降滑轮。注意:支撑滑轮没有放在这桁上。
    Mizen Topsail Yard: Shows the Mizen topsail yard, tie blocks, quarter blocks, lift blocks, topsail parrel, eye-lets for the jack-stay.
    后桅上桅帆桁:显示了后桅上桅帆桁、系滑轮、转角滑轮、升降滑轮,上桅帆索箍,为了支索的鸡眼。
    Mizen Top Gallant Yard
    后桅桅楼Gallant桁
    Mizen-Mast: Mizen mast and sails.
    后桅:后桅和帆
    Lateen Sail: Shows the Mizen mast topsail shrouds, reef band, reef points on the lateen sail, and the foot-ropes on the cross-jack yard.
    三角帆:显示了后桅上桅帆上下桅连接索,三角帆上的卷帆带、卷帆点,和后桅下桁上的脚绳。
    Cross-jack Yard: Shows the standing rigging on the cross-jack yard.
    后桅下桁:显示了后桅下桁上的静索。
    Mizen Top-Mast Shroud Shows the reef band, cringles, and points on the sails.
    后桅桅楼-上下桅连接索:显示了帆上的卷帆带,缝边,和点。
    Fore Mast
    前桅
    Fore Mast Lower Yard: Shows the blocks on the lower yard, the yards are the same as the main mast yards. The blocks on the lower yard, from left to right are as follows: lift block and brace block, which has not been put over the yard arm as of yet, leech line blocks, clue garnet blocks, topsail sheet blocks, and then the jeer blocks. The same on the other side of the yard.
    前桅下桁:显示了下桁上的滑轮,这个桁与主桅桁是一样的。下桁上的滑轮从左到右是升降滑轮和支撑滑轮(没有安放到桁上),帆端上拉索滑轮、clue garnet滑轮、上桅帆滑轮,和jeer滑轮。桁的另一边是一样的。
    Fore-Topsail Yard: Shows the standing rigging on the topmast yard.
    前上桅帆桁:显示了上桅帆桁上的静索。
    Fore-Mast: A view looking up at the Fore mast.
    前桅:向上看前桅。
    Foot-Ropes: Shows the stirrups,foot ropes, studding-sail boom, and the flemish horses.
    脚绳:
    [ 本帖最后由 old_cobra 于 2009-4-26 16:19 编辑 ]
  • 发表于 2009-3-20 11:29:06 | 显示全部楼层
    非常好的资料,又一次学习了[mftnrd]
  • 发表于 2009-3-20 12:58:43 | 显示全部楼层
    [vse4bb] [vse4bb] [vse4bb] 一次图片太多,打开有点吃亏哦。
  • 发表于 2010-12-19 09:43:13 | 显示全部楼层
    很细致的教程啊{:soso_e179:}
  • 发表于 2011-9-5 11:16:21 | 显示全部楼层
    做的很细,就是感觉桅杆的油漆有点刷多了。
    骑士111 该用户已被删除
    发表于 2012-5-23 23:08:19 | 显示全部楼层
    GMT+8, 2024-12-1 11:40 , Processed in 0.095422 second(s), 28 queries .
