楼主: 曾先科
CB90[突击艇,即将上市,欢迎订购,有意请联系13413339882
曾先科 该用户已被删除
 楼主| 发表于 2012-7-13 12:00:30 | 显示全部楼层
桂0774 该用户已被删除
发表于 2012-7-13 16:50:12 | 显示全部楼层
  • 发表于 2012-8-30 21:53:13 | 显示全部楼层
    19# g4ing
    这是实话了,我想做喷水动力的,一套喷水动力两个要2000多元,成本太高了。
    曾先科 发表于 2012-7-7 22:42
    两台喷泵两千多,是什么材质啊?全金属的就不算贵,加波箱和船体应该不会超过1W吧,玩起来乐趣会多好多啊!
    发表于 2012-8-30 22:26:31 | 显示全部楼层
    43# dym
    保守估計光是動力部份就7000以上了
    進口电油机用的噴筒2500-3500一組
    好點無刷電變電机1500-2000一組
    发表于 2012-8-30 22:54:08 | 显示全部楼层
    {:soso_e103:}·····AR老师·你报的是金属喷水推进的价格吧?
    无刷电机贵··
    发表于 2012-8-31 00:04:33 | 显示全部楼层
    http://www.jet-drive.de/index.ph ... id=11&Itemid=17
    View Full-Size Image
    40-mm-Power-Jet with steering and reverse system
    11-1/2" long, 2-1/2" wide. Weighs 10.5 oz.
    This is perhaps the EASIEST drive system to install in a fast boat. It can be installed into deep-V猀, and flat bottom boats with by just making a simple cutout and some reinforcement in the boat bottom.
    Turn rudders and reverse bucket are included.
    Use glow engines from .21 to .90.
    Design of the suction channel allows running at a pronounced tilt or in rough water. There猀 no prop or rudder damage from running over rocks or other obstacles.
    Strong glass fiber-filled nylon construction.
    Shaft is 7 mm but the end to be coupled to a motor is 5 mm.
    Impeller diameter is 40 mm (1.58")
    tunnel dimensions        :        length: 170 mm
    width: 55 mm
    height: 55 mm
    steering system dimensions        :        flange diameter: 66 mm
    length: 110 mm
    width: 60 mm
    height: 50 mm
    recommended engines        :        22 ccm Zenoah or similar
    static thrust        :        more than 1500 W
    10.000 - 15.000 rpm
    5 - 8 kp
    operational range        :        10.000 - 15.000 rpm
    Price per Unit (Stück): 99,00  (including 19 % tax)
    Bestellnr.: JET-P4001
    发表于 2012-8-31 03:51:43 | 显示全部楼层
    99欧元=785.7143人民币元一套?
    {:soso_e113:} 我开发套?(外玻璃钢壳或者塑料壳内金属CNC螺旋桨)
    AR老师喜欢三更出来逛论坛?
    发表于 2012-8-31 09:41:47 | 显示全部楼层
    AR老师喜欢三更出来逛论坛?
    天空の牧场`. 发表于 2012-8-31 03:51
    那些有錢也很難訂回來
    如果要自己造也不是太難,只是效果很低
    年紀大了是的喜欢三更出来逛(半百)
    发表于 2012-8-31 09:45:32 | 显示全部楼层
    国內出品不知效果如何
    大脚仔 该用户已被删除
    发表于 2012-8-31 10:46:46 | 显示全部楼层
    GMT+8, 2025-3-2 02:42 , Processed in 0.086547 second(s), 21 queries .
